How to pass dynamic border colours for all widgets in thingworx mashup development?
You can also refer following article which might be helpful here
https://www.ptc.com/en/support/article/CS390613?source=search
https://www.ptc.com/en/support/article/CS428654?source=search
https://www.ptc.com/en/support/article/CS350484?source=search
Similar discussion - "Dropdown widget color dynamically as per selection of value": https://community.ptc.com/t5/ThingWorx-Developers/Dropdown-widget-color-dynamically-as-per-selection-of-value/td-p/780230
Hello @AP_10343008,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Hi @AP_10343008,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to support.
Abhi
Hi @AP_10343008,
I wanted to follow up with you on your post. Upon further review, we have gone ahead and designated the post we feel successfully answered your question.
In the event that you disagree with the Solution Accepted, please let me know.
Thanks for using the PTC Community!
Abhi
