can you tell me how to use validator in thingworx 8.4?
I have created validator and added a parameter. Service Output as input the parameter and service invoke complete will evaluates the validator.
I fell I have provided wrong expression which is giving true as output all the time.
With the above screenshot please tell me where I'm wrong.
Hi @BhavyaPC.
While testing under 8.5.4, we noticed the following:
Can you try these in your environment and advise the status?
Note, there is an improvement coming in the 9.0 release targeted for June.
--Sharon
No luck, I tried Mashupload and AutoEvaluate every time it gives true output.
My objective is to Rename the file uploaded by user Through fileupload widget.
Fileupload complete triggers/Navigates Popup, on selecting row of a grid and clicking on apply button popup closes and a service will be called to rename the file uploaded. - Issue with this approach is If user didn't select any any row in the popup uploaded file name will not change.
Second approach I tried is,
Since validator is giving true all the time popup will be open all the time.
Also on upload complete wil
Could you suggest me if any other approach can be followed.
Hi @BhavyaPC.
Since you seem to be encountering issues that we aren't seeing under 8.5.4, it might be best to open a case for this issue. I wasn't able to find your email address set up in our systems, but if you have a support account under a different email address, let me know and I'll be happy to open the case on your behalf.
Something else to check, is the full version of the product your are running. You can get this information by checking Help > About in the upper-right corner of the Composer window. You mentioned 8.4, but we have released several patch updates.
--Sharon
