How to pass json to the rest api
nbhagtani
2-Guest
I have got json to pass to the rest api.
created json:
  "Path": "sample string 1",
  "Name": "sample string 2",
  "Value": "sample string 3",
  "TimeStamp": "sample string 4"
if am using postJson method how to pass above json to PostJson  method?
Hi Nisha,
Just populate the content parameter with your Json.
For example :
var myJson = {
var params = {
    headers: myHeader /* JSON */,
    url: myUrl /* STRING */,
    content: myJson /* JSON */,
// result: JSON
var result = Resources["ContentLoaderFunctions"].PostJSON(params);
posipova
20-Turquoise
(To:nbhagtani)
Hi Nisha,
For example :
var myJson = {
var params = {
// result: JSON
Hi Stephane,
if my rest service is returning boolean so will i get that in result using PostJson?
Thanks it worked
