I'm trying to implement a page where I have around 8 icons and when Mouse over or button click happen to the icon an expanded area of sub menu icons has to come up by making remaining area and icons gray.
Anyone please let me know how can I achieve this.
Thanks in advance
Can you attach a screenshot of your mashup? I don't know you're referring to a Expanded Menu-submenu or a layout (expand with siderbar?) .
Thank you zyuan1,
The requirement is to build a responsive mashup with background image, icons as in the below image. On mouse hover or click on the icon, all other icons has to go gray and the area below the icon has to get expanded with sub activities of the respective.
In the second image attached, only Projects highlighted with a small expanded area between two rows and activities related to that.
Image 1
Please let me know is there any possibilities to achieve this .
For the expanding designs I know, you can use expandable sidebar/header/footer, Popup and Folding panel.
Folding panel does not fit for your UI; Popup can disable other widgets (turn grey); and with siderbars you can choose to interact with other widgets or not.
I have divided mashup layout into required number of layouts, in every layout I have taken a footer which will hold the sub menu of respective. Also provided on click expansion of the footer but this is not meeting the expectations.
expected that expansion should happen downwards, other icons turn gray, mouse hover highlight is not happening for other icons.
Yes you did, and just bind the Expanded property of the Footer to the Widgets above on the Disabled property, then if you can see the Footer, the widgets will be grey, and won't change color when you hover over.
When it's expanded, all other widgets are grey and disabled, when it's folded, other widgets went normal.
Didn't you realize this function or you have extra request?
No, I haven't tried that. Since the requirement is to expand the area we had given footer expansion they are not satisfied. Looking for different method to achieve this .
Hi @BhavyaPC.
If you have found a solution, please feel free to post it here and mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
Hi Sharon,
I didn't find a solution, surely I'll post if I get it.
Regards
Bhavya
Use a Left/Right side bar and expand when selected should be more friendly in both design and user experience.
Or you can try to persuade client to use Popup window
Thanks @zyuan1 ,
I have tried this method earlier, Since we have very less space we can't place icons in the expanded panel, they look very tiny and not good UI/UX
How many expandable icons are you expecting? Sidebars/Footer can cover more than 50% of the screen if you allow so the space is not a problem, you can also you contained mashup in Sidebars/ Navigator to open new mashups in response to the selected Icon.
There are around 8 icons, which has minimum of 3 sub icons(clickable/Navigator), Since UI has other components we can't provide 50% of space in any manner.
Number of icons will deffer based on the result of a service.
