How to quickly add properties in thingshape?
Snoopy_hu
9-Granite
Hi @Snoopy_hu
As @Rocko  mentioned it is not visible to the end user. But you can create custom service to do it
ThingShapes["SHAPE_NAME"].AddPropertyDefinition({
	indexed: undefined /* BOOLEAN {"defaultValue":false} */,
	defaultValue: undefined /* STRING */,
	remoteBindingAspects: undefined /* JSON */,
	description: undefined /* STRING {"defaultValue":""} */,
	readOnly: undefined /* BOOLEAN {"defaultValue":false} */,
	type: undefined /* BASETYPENAME */,
	remote: undefined /* BOOLEAN {"defaultValue":false} */,
	remotePropertyName: undefined /* STRING */,
	timeout: undefined /* INTEGER {"defaultValue":0} */,
	pushType: undefined /* STRING */,
	dataChangeThreshold: undefined /* NUMBER */,
	logged: undefined /* BOOLEAN {"defaultValue":false} */,
	name: undefined /* STRING */,
	pushThreshold: undefined /* NUMBER */,
	dataChangeType: undefined /* STRING */,
	category: undefined /* STRING */,
	persistent: undefined /* BOOLEAN {"defaultValue":false} */,
	dataShape: undefined /* DATASHAPENAME */
/VR
6 REPLIES 6
Hi @Snoopy_hu
Do you mean adding property through service ?
https://www.ptc.com/en/support/article/CS233812
/VR
Hi @Velkumar
Thanks! I would like to add multiple attributes through a service, I tried the help you provided and found it, but unfortunately why doesn't thingshape have this service?
Rocko
(To:Snoopy_hu)
ThingShape is not in the same inheritance line as ThingTemplate and therefore the services are not visible to the end user.
Snoopy_hu
9-Granite
(To:Rocko)
Hi @Rocko
I see. Thank you.
Hi @Snoopy_hu
/VR
Hi @Velkumar
I really didn't think there was a way to do this, thank you so much!
