Hi @Snoopy_hu
As @Rocko mentioned it is not visible to the end user. But you can create custom service to do it
ThingShapes["SHAPE_NAME"].AddPropertyDefinition({
indexed: undefined /* BOOLEAN {"defaultValue":false} */,
defaultValue: undefined /* STRING */,
remoteBindingAspects: undefined /* JSON */,
description: undefined /* STRING {"defaultValue":""} */,
readOnly: undefined /* BOOLEAN {"defaultValue":false} */,
type: undefined /* BASETYPENAME */,
remote: undefined /* BOOLEAN {"defaultValue":false} */,
remotePropertyName: undefined /* STRING */,
timeout: undefined /* INTEGER {"defaultValue":0} */,
pushType: undefined /* STRING */,
dataChangeThreshold: undefined /* NUMBER */,
logged: undefined /* BOOLEAN {"defaultValue":false} */,
name: undefined /* STRING */,
pushThreshold: undefined /* NUMBER */,
dataChangeType: undefined /* STRING */,
category: undefined /* STRING */,
persistent: undefined /* BOOLEAN {"defaultValue":false} */,
dataShape: undefined /* DATASHAPENAME */
/VR
Hi @Snoopy_hu
Do you mean adding property through service ?
https://www.ptc.com/en/support/article/CS233812
/VR
Hi @Velkumar
Thanks! I would like to add multiple attributes through a service, I tried the help you provided and found it, but unfortunately why doesn't thingshape have this service?
ThingShape is not in the same inheritance line as ThingTemplate and therefore the services are not visible to the end user.
Hi @Snoopy_hu
/VR
Hi @Velkumar
I really didn't think there was a way to do this, thank you so much!
