I want to reduce the spaces between two lines of bar chart and also want reduce their width how can I do that
as you can see the image I want there width should be minimum and also gap between these two as well
Hi @LY_10691079 <
Try the below Padding in the Style Properties; for me, it worked.
Hi @LY_10691079 Look at the below reference link, and let me know if it will work in your case or not.
Hi @LY_10691079 <
