How to remove the last unnecessary column in the grid ?
Dabbler_Aish
8-Gravel
Grid_Extra_Column.pngI have only created 3 columns in the grid. The fourth one appears as an extra and there is no need for it. Removing this extra column will greatly help in improving the look and feel of the grid. So how can the last column (unnamed column in the marked in red in the image) be removed.
slangley
(To:slangley)
Hi @Dabbler_Aish.
From further investigation, it was found that this issue was reported some time ago.  Unfortunately, it was deemed low priority and at this time, there are no plans to fix it.
Please let us know if you have further questions.
--Sharon
8 REPLIES 8
slangley
(To:Dabbler_Aish)
Hi @Dabbler_Aish.
Are you seeing this only at runtime?  If you select the drop-down in the upper left corner of the widget and select Configure Grid Columns, does it show only the columns that you expect to see?
To recreate this issue, please provide the ThingWorx version you're running and more details around the mashup.  What are you binding to the grid?  Are you using the grid widget out of the box or the Advanced Grid widget from the marketplace?
--Sharon
I am using ThingWorx 8.2 version, Binding to a select query of an external Database. And we are using an Advanced grid. Instead of configuring the grid column's width manually using dropdown, Is there any other way to fix the grid columns to space evenly and exclude the extra column spacing?
slangley
(To:Dabbler_Aish)
Hi @Dabbler_Aish.
One other question.....
Which browser are you using?  If you test under different browsers, do you get the same results?
--Sharon
slangley
(To:slangley)
Hi @Dabbler_Aish.
Just wondering if you found a solution to your problem.  If you have resolved, please post it here for the benefit of others on the community.
If you are still having an issue, please provide the details requested in the previous posts so we can review further.
--Sharon
slangley
(To:slangley)
Hi @Dabbler_Aish.
--Sharon
slangley
(To:slangley)
Hi @Dabbler_Aish.
We realize the answer to your question is not the solution you were searching for, but as it does answer the question, please mark the last reply as the Accepted Solution for the benefit of others with the same question.
--Sharon
Very Sorry for the late reply @slangley .
Thanks a ton for stepping in to help us out!!
GIRD VERSION : grid-advanced_ExtensionPackage-4.1.0
THINGWORX VERSION: ThingWorx 8.2.5-b260
Yes all browsers give same issue exits
slangley
(To:slangley)
Hi @Dabbler_Aish.
Which version of the Advanced Grid widget are you using?  Have you tried a different version?
Is ThingWorx 8.2 the full version?  You can find this information by selecting Help > About on the upper toolbar.
--Sharon
