How to setting line graph
DR_10558933
8-Gravel
Now i got line chart like picture below but i want to modify something
1.X-Axis that is a time didn't show full date
2.On the right hand side, i want to edit sequence that L.33 is first one and then L.34 , L.35 respectively.
Thank you
Velkumar
(To:DR_10558933)
Hi @DR_10558933
For Line Chart, you can try changing XAxisType to Date/Time and set XAxisDateFormatToken. Also, set HorizontalAxisLabelsRotation to 0.
In Widget Style Properties, reduce Xaxis Tick Label font size  to fit into the chart
For sequence, you can set NumberOfSeries to 7. Select DataField based on your sequence
/VR
5 REPLIES 5
Velkumar
(To:DR_10558933)
Hi @DR_10558933
/VR
another question, can i change format when i put the mouse to some point at the line chart ?Untitled.jpg
Velkumar
(To:DR_10558933)
HI @DR_10558933
For custom tooltip please refer here - Creating Custom Chart Tooltips (ptc.com)
/VR
How i can custom the ${label} to get short detail and disable value at graph that show upper pointer
Velkumar
(To:DR_10558933)
Hi @DR_10558933
I don't think we can customize label value in Mashup Runtime.
If you want a custom label, you can add a new field with a custom value and update the tooltip with Template Literals
To display custom field as Tooltip
${Data:<Infotable-field>}
Article -
Article - CS369558 - Using Custom Tooltips in Line Chart in ThingWorx Platform (ptc.com)
Article - CS381734 - The tooltip for the Line Chart Widget does not honor the date format of the x-axis label in ThingWorx (ptc.com)
The article says that the issue was fixed in 9.3.4 but it is still not working
/VR
