How to setup to connect apache-hive-server with JDBC?
nt
Hi.
I want to connect from thingworx to the apache-hive-server with JDBC. but, i'm run into probrem.
connection-pool settings occured something wrong? Network is not wrong.(Other java native client is correct moving.)
my settings
error message.
■ApplicationLog:
2015-11-30 16:11:18.328+0900 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-80-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@11123240][message: Unable to Invoke Service SelectData on hiveConnection : Cannot get a connection, pool error Unable to validate object]
・ "Cannot get a connection, pool error Unable to validate object"
-> "connectionValidationString" is wrong?
i tried to enter "select now()" and "select 1" and "select * from dual" ,
but still give same error.
■Added Libraries for Hive JDBC
slf4j-log4j12-1.5.11.jar
slf4j-api-1.5.11.jar
log4j-1.2.16.jar
libthrift-0.9.2.jar
httpcore-4.2.5.jar
httpclient-4.2.5.jar
hive-service-1.1.1.jar
hive-jdbc-1.1.1.jar
hive-common-1.1.1.jar
hive-cli-1.1.1.jar
hadoop-common-2.7.1.jar
guava-18.0.jar
commons-logging-1.1.3.jar
ThingWorx version is 5.4
Please let me know how connect apache-hive-server.
Thanks.
3 REPLIES 3
maneeshr
7-Bedrock
(To:nt)
Nakam t Could you please send your "catalina.properties" file of tomcat?
nt
(To:maneeshr)
Hi Rao.
thank you for your reply.
This is all "catalina.properties" file of tomcat.
--catalina.properties (exclude comments)----------------------------------------------
package.access=sun.,org.apache.catalina.,org.apache.coyote.,org.apache.jasper.,\
org.apache.naming.resources.,org.apache.tomcat.
package.definition=sun.,java.,org.apache.catalina.,org.apache.coyote.,\
org.apache.jasper.,org.apache.naming.,org.apache.tomcat.
common.loader=${catalina.base}/lib,${catalina.base}/lib/*.jar,${catalina.home}/lib,${catalina.home}/lib/*.jar
server.loader=
shared.loader=
tomcat.util.scan.DefaultJarScanner.jarsToSkip=\
bootstrap.jar,commons-daemon.jar,tomcat-juli.jar,\
annotations-api.jar,el-api.jar,jsp-api.jar,servlet-api.jar,websocket-api.jar,\
catalina.jar,catalina-ant.jar,catalina-ha.jar,catalina-tribes.jar,\
jasper.jar,jasper-el.jar,ecj-*.jar,\
tomcat-api.jar,tomcat-util.jar,tomcat-coyote.jar,tomcat-dbcp.jar,\
tomcat-jni.jar,tomcat-spdy.jar,\
tomcat-i18n-en.jar,tomcat-i18n-es.jar,tomcat-i18n-fr.jar,tomcat-i18n-ja.jar,\
tomcat-juli-adapters.jar,catalina-jmx-remote.jar,catalina-ws.jar,\
tomcat-jdbc.jar,\
tools.jar,\
commons-beanutils*.jar,commons-codec*.jar,commons-collections*.jar,\
commons-dbcp*.jar,commons-digester*.jar,commons-fileupload*.jar,\
commons-httpclient*.jar,commons-io*.jar,commons-lang*.jar,commons-logging*.jar,\
commons-math*.jar,commons-pool*.jar,\
jstl.jar,\
geronimo-spec-jaxrpc*.jar,wsdl4j*.jar,\
ant.jar,ant-junit*.jar,aspectj*.jar,jmx.jar,h2*.jar,hibernate*.jar,httpclient*.jar,\
jmx-tools.jar,jta*.jar,log4j.jar,log4j-1*.jar,mail*.jar,slf4j*.jar,\
xercesImpl.jar,xmlParserAPIs.jar,xml-apis.jar,\
junit.jar,junit-*.jar,hamcrest*.jar,org.hamcrest*.jar,ant-launcher.jar,\
cobertura-*.jar,asm-*.jar,dom4j-*.jar,icu4j-*.jar,jaxen-*.jar,jdom-*.jar,\
jetty-*.jar,oro-*.jar,servlet-api-*.jar,tagsoup-*.jar,xmlParserAPIs-*.jar,\
xom-*.jar
org.apache.catalina.startup.ContextConfig.jarsToSkip=
org.apache.catalina.startup.TldConfig.jarsToSkip=tomcat7-websocket.jar
tomcat.util.buf.StringCache.byte.enabled=true
Nakam
nt
(To:nt)
ThingWorx is to use method - "PreparedStatement.setQueryTimeout", but that is not supported on hive-jdbc.
this is more information log.
PoolableConnectionFactory - Failed to validate a poolable connection
java.sql.SQLException: Method not supported
  at org.apache.hive.jdbc.HiveStatement.setQueryTimeout(HiveStatement.java:739)
  at org.apache.commons.dbcp2.PoolableConnection.validate(PoolableConnection.java:234)
  at org.apache.commons.dbcp2.PoolableConnectionFactory.validateConnection(PoolableConnectionFactory.java:303)
  at org.apache.commons.dbcp2.PoolableConnectionFactory.validateObject(PoolableConnectionFactory.java:288)
  at org.apache.commons.pool2.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:488)
  at org.apache.commons.pool2.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:361)
  at org.apache.commons.dbcp2.PoolingDataSource.getConnection(PoolingDataSource.java:102)
  at com.thingworx.things.database.QueryHandler.internalExecute(QueryHandler.java:51)
public void setQueryTimeout(int seconds) throws SQLException {
  throw new SQLException("Method not supported");
Thank you for your support!
