My code is to get a new field of location from available column longitude, latitude, elevation. Built with no error.
// result: INFOTABLE dataShapeName : "MapData"
var result = Things["ThingName"].ServiceName(); // Change the ThingName and Service name herevar newField = new Object();
newField.name = "location";
newField.baseType = 'LOCATION';
result.AddField(newField);// location:LOCATION
var temp = new Object();var tableLength = result.rows.length;
for (var x = 0; x < tableLength; x++) {
var row = result.rows;
temp.latitude = row.latitude;//result.rows.latitude;
temp.longitude = row.longitude;//result.rows.longitude;
temp.elevation = 0;
temp.units = "WGS84";
row.location = temp;
But the output is like this. The location column is all NaN:NaN. Something is wrong?
The "result" in my test is a new InfoTable of DataShape NamedVTQ, created directly in service. Then I added 10 rows with only "value" before adding the new field "location". The "latitude" and "longitude" are just 0,1,2...
var data = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({dataShapeName: "NamedVTQ"});
for (var i = 0; i < 10; i++) {
data.AddRow({name: "name_" + i}) ;
newField.name = "mylocation";
data.AddField(newField);
var tableLength = data.length;
for (var x = 0; x < 10; x++) {
var row = data
; var tmp = new Object();
tmp.latitude = x;
tmp.longitude = x * 10;/
tmp.elevation = 0;
tmp.units = "WGS84";
// 3 rows below work
// data
.mylocation = tmp; // data.rows
.mylocation = tmp; row.mylocation = tmp;
data.AddRow({mylocation: tmp, value: tmp.latitude});
data
.value = tmp.latitude; }
data.AddRow({mylocation: tmp, name: "name_99", value: 99});
logger.debug(data.rows);
result = data;
Pleas move
inside for loop
other wise you are setting all the location field to one object and do the change on one object
YUanwu Shen
My code is like this now:
; var temp = new Object();
temp.baseType = 'LOCATION';
temp.elevation = 0;
result.rows
.location = temp; }
My output still the same...
Dear Yuan Wu,
Thanks for your help. Please see my latest update. There is new problem in the google map... Maybe the precision of the digits in the location?
In the loop script,
So I think the code is right.
The behavior is weird. Before the end of for loop, if I add "result.AddRow({location: temp}), the new rows are added with correct location. When I log the result, the data structure is different too.
"location" where is Nan: "location={"elevation":1.0,"latitude":1.0,"units":"WGS84","longitude":0.0}"
Correct "location" added at the end of result: "location=1.0,1.0,0.0"
That's Strange because it works fine for me.
The only difference is I am not using the DataBase. My data is stored in a DataTable.
var row = data
tmp.latitude = x;
tmp.elevation = 0;
// data
data
result = data;
Yes. If I add the a new row,
temp.elevation = 0;
result.rows.location = temp;
result.AddRow({location: temp});}
The result is right then:
Hi Tiantian Guo,
Based on Quang input; I have following suggestion:
1. Create a new DataShape which has all the fields you require + location field. DataShape1
2. In custom Service create a new Infotable using above DataShape.
var params = {
infoTableName: "INFOTABLE" /* STRING */,
dataShapeName: "DataShape1" /* DATASHAPENAME */
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
3. Loop though the old infotable (let's say result1) and Add the Row to the new infotable (result).
var tableLength = result1.rows.length;
temp.elevation = 0;
temp.latitude = result1.rows
.latitude; temp.longitude = result1.rows
.longitude; var temp1 = new Object();
temp1.latitude = result1.rows
.latitude; temp1.longitude = result1.rows
.longitude; temp1.location = temp;
result.AddRow(temp1);
I hope it helps.
Dear Ankit,
I got the right result using your code.
And I attach the result to the google map,
There are nothing appearing.
I thought maybe the precision of the location, there are lacking two digits from the original latitude and longitude..
Hi Tiantian Guo,
Could you please start a new Thread for this issue and add a Screenshot of Google widget properties.
Have you selected the location column for location property in Google widget?
Dear Ankit,
I have selected the location column for location property.
