How to trigger navigation logic using Mashup Master and simple Mashups
maccagnoda
2-Explorer
Hello Everyone,
i would like to create a navbar for my master mashup. I can see my mashups in the menu widget, but if click on a mashup button in the menu i simply navigate to the mashup, leaving the master. It seems that is working as a simple link. Could you please help me?
Velkumar
(To:maccagnoda)
You can set same Master for all Mashup. So that when you navigate from one Mashup to another, Master will be available.
/VR
Thanks for your reply,
Every widget is linked to the related master using the "master" property. But it's seems that i've missing something
Here's my steps:
- created Mashups
- created Master with a "contained mashup" widget and menu widget
- created a menu object with all the mashups i need
- linked this menu object to the menu widget
- the outgoing property of the menu widget is linked ( as input ) to the mashup property in the contained-mashup widget
- Every widget is correctly configured with the same master
am i missing something?
best regards
Velkumar
(To:maccagnoda)
Its perfect. You are not missing anything. It will be helpful if you also share some mapping screenshot or some entities to test.
/Vr
Velkumar
(To:Velkumar)
PFA entities for your reference. I'm able to navigate between 2 mashups with same master.
