How to update the state definitions rgb value using js services?
AP_9587236
try to use below code..
let params = {
	name: 'testStyle' /* STYLEDEFINITIONNAME */,
	content: { "content" :
                  {   "params": "",
                       "image":"",
                       "backgroundColor":"#d49d13",
                       "textSize":"normal",
                       "lineStyle":"dotted",
                       "displayString":"Series 15",
                       "fontEmphasisUnderline":false,
                       "fontEmphasisItalic":false,
                       "lineThickness":1,
                       "lineColor":"#ffac20",
                       "foregroundColor":"#ffdc84",
                       "fontEmphasisBold":false,
                       "secondaryBackgroundColor":"#ffb22f"
                 } /* JSON */
// no return
Resources["EntityServices"].UpdateStyleDefinition(params);
Also refer... https://community.ptc.com/t5/ThingWorx-Developers/Style-definition-using-scripts/td-p/606413
3 REPLIES 3
User will select colour name from list widget, then a service should triggered to update the corresponding rgb colour of selected colour name in the state definition. How to do this ?
slangley
23-Emerald II
(To:AP_9587236)
Hi @AP_9587236.
Can you explain your use case?  Are you trying to modify the state definition from a service in a mashup or API call?
--Sharon
let params = {
                  {   "params": "",
                       "image":"",
                       "lineThickness":1,
                 } /* JSON */
// no return
