How to use drop down widget
Rayon_11
Hi All,
I want to a help like suppose I have a dropdown widget and a grid widget now in the dropdown widget we can have many item now I want is if suppose I choose one item from the drop down then its whole property (like different column) should be displayed in the grid widget so to do this what are the things which I have to do please help me to do so
Thanks in Advance
Rayon.
1 ACCEPTED SOLUTION
PEHOWE
(To:PEHOWE)
@Rayon_11 , Here is an export which created the above mashup. Let me know if you have questions.
3 REPLIES 3
HI @Rayon_11 ,
If I'm understanding properly in your case,
  • Please create the your logics in service as infotable output with defined Datashape fields
  • Call the service in your mashup and Bind Service's All Data to Dropdown widget & select the fields of "DisplayField, ValueField, StateField"
  • Then you can use "SelectedRows" of dropdown service as input to your Grid "Data" to find which row is selected in the dropdown with all column values.
Thanks & Regards,
Arun C
@Rayon_11 ,
I am not sure exactly what you are requesting. Here is a screen capture of a mashup. The selection in the dropdown causes an update in the grid.
PEHOWE
(To:PEHOWE)
