Hi All,
I want to a help like suppose I have a dropdown widget and a grid widget now in the dropdown widget we can have many item now I want is if suppose I choose one item from the drop down then its whole property (like different column) should be displayed in the grid widget so to do this what are the things which I have to do please help me to do so
Thanks in Advance
Rayon.
@Rayon_11 , Here is an export which created the above mashup. Let me know if you have questions.
HI @Rayon_11 ,
If I'm understanding properly in your case,
Thanks & Regards,
Arun C
I am not sure exactly what you are requesting. Here is a screen capture of a mashup. The selection in the dropdown causes an update in the grid.
