hi all,
my use case is,
i want to trigger a service when i hover my mouse over a grid.
how idea or work around how i can achieve this?
Hi @CharanCr.
This is not recommended. You could inadvertently make changes just by hovering when it was not intended. There is a double-click event that may be better suited to your purposes.
--Sharon
Hi @CharanCr.
--Sharon
Hi @CharanCr.
If you feel that the previous reply answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
