How we can handle offset in thingworx
Hrishabh.Sharma
11-Garnet
@Name: Hrishabh Sharma
Composer INPUT Offset = result = (new Date()).getTimezoneOffset(); ----Note: Input (offset) shoud be from In Composer (Expression)
try {
var startDateSelected;
var endDateSelected;
var StrandName = Strand_Name;
if (Offset === undefined || Offset === null || Offset === 0) {
Offset = (new Date()).getTimezoneOffset();
var diff1 = (Offset - (new Date()).getTimezoneOffset()) * -1;
var diff2 = (Offset - (new Date()).getTimezoneOffset()) * 1;
if (Start_Date !== undefined) {
startDateSelected = dateAddMinutes(Start_Date, diff1);
if (End_Date !== undefined) {
endDateSelected = dateAddMinutes(End_Date, diff1);
// result: INFOTABLE dataShape: "CastingStrandParameterLog_DS"
var result1 = Things["Postgresql_TH"].CastingStrandReportForVisualization({
Enddate: endDateSelected /* DATETIME */ ,
Startdate: startDateSelected /* DATETIME */ ,
StrandName: StrandName /* STRING */
var sorted_infotable = result1;
var rowSize = sorted_infotable.getRowCount();
me.tes = rowSize;
for (var m; m < rowSize; m++) {
if (diff2 !== 0) {
sorted_infotable.rows[m].timestamp = dateAddMinutes(sorted_infotable.rows[m].timestamp, diff2);
var result = sorted_infotable;
} catch (e) {
logger.error("Thing: DataServices_TH Services: CastingStrandReportForVisualization ERROR: " + e.message + "Line Number: " + e.lineNumber);
Hi @Hrishabh.Sharma
(new Date()).getTimezoneOffset() is the only way to get client browser timezone and handle it in Thingworx.
/VR
5 REPLIES 5
Hi @Hrishabh.Sharma
Could you please explain your use case
/Vr
I'm just asking. Is there any other way to do that things.
if you have any other way or you how to handle that case.
Hi @Hrishabh.Sharma
/VR
Hello @Hrishabh.Sharma
It looks like you have some responses from a community member. If it helped to answer your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
