Composer INPUT Offset = result = (new Date()).getTimezoneOffset(); ----Note: Input (offset) shoud be from In Composer (Expression)
(new Date()).getTimezoneOffset() is the only way to get client browser timezone and handle it in Thingworx.
/VR
I'm just asking. Is there any other way to do that things.
if you have any other way or you how to handle that case.
/VR
Hello @Hrishabh.Sharma,
It looks like you have some responses from a community member. If it helped to answer your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
