Hybrid graph to show Line and dot for multiple series in ThingWorx 9.1
RK_0705
11-Garnet
Hi Team,
How to display one series on graph as dot and on same graph other series as line? (X axis will be as timestamp and y-axis should be numeric)
Can anybody let me know the exact graph as well as the process to plot this type of hybrid graph.
Thanks in advance.
PaiChung
22-Sapphire I
(To:RK_0705)
I believe if you look at the Line Chart and the Time Series Chart, you can define this per series? I apologize if this is not the case.
Hi @PaiChung
I don't want to show marker and line together on same line and show the data only in line/marker format as we can achieve this in line chart.
Actually in my use case , I have to show some series data points only with marker i.e. as dots(without running line) and some series in the form of running line.
It is like the join of line chart and scattered dot chart.
Please advise.
Hello @RK_0705 ,
Kindly check the given link  :
How to customize a trace?
Bhawna
