I need tutorial about MicroServer & Android SDK
CHASEONHO
18-Opal
Hi , i'm SeonHo
and i'm Thingworx newbie in Korea
I need an example of setting up MicroSever and creating and connecting a Thing in Thingworx.
I also want to get Thingworx property values using the Android SDK.
I would also like to configure APP to log in to Thingworx on mobile.
But I have a hard time with the lack of related materials.
Answers I'll wait.
Thank you.
P.S.
Is there a document that demonstrates the great strengths and advantages Thingworx has over other IoT platforms, and what makes it better than other open source platforms?
dupatel
(To:CHASEONHO)
11 REPLIES 11
AnnaAn
(To:CHASEONHO)
seonho Cha​,
If you could have access to our support website, you should get such materials from:
Edge MicroServer: How to use Edge MicroServer
Hi An
i can access to support website..
but when i click that lick appear
PTC is currently experiencing systems issues on its infrastructure and Customer Support systems. During this time there will be no access to www.ptc.com. We apologize for any inconvenience.
Platinum Enterprise support level customers may still contact PTC Technical Support at the normal Worldwide Technical Support telephone numbers listed below. Please note that Support Engineers will have limited access to support tools during the maintenance work.
AnnaAn
(To:CHASEONHO)
seonho Cha​,
Could you try again now? I could access to it but I am not sure if it's internal accessible only; but people outside PTC should have access to it; try to login another time and let us know if it still wouldn't work.
Anna
Hi Anna An
I have tried this many times.
Today morning from until now
But still I can not access that link
dupatel
(To:CHASEONHO)
seonho Cha​: Could you please try the below URL if that works for you regarding Edge Microserver:
https://support.ptc.com/WCMS/files/173143/en/ThingWorx_WebSocket_based_Edge_MicroServer_Developer_Guide_v.5.3.4.pdf
Hi Durgesh Patel
i can access your link
is it same DOC?
thanks
dupatel
(To:CHASEONHO)
seonho Cha​: Yes, the same document however it points to the latest available documentation on the topic.
-Durgesh
AnnaAn
(To:CHASEONHO)
Hi seonho Cha​,
My apologize!
I gave you an internal access link; please refer with the link Durgesh provided.
and also you could check in the same place for Android SDK user guide:
https://support.ptc.com/WCMS/files/170147/en/ThingWorx_Edge_Android_SDK_Developer_Guide_v1.0.pdf
Br,
Anna
Anna An
Thanks!!
Really!
But I did check the correct answer to Durgesh Patel gave me the link to access!
AnnaAn
(To:CHASEONHO)
seonho Cha​,
That does not matter at all!
Feel free to raise your questions/concerns in this awsome community:)
jebeck
(To:CHASEONHO)
There are also a couple of good guides on the ThingWorx Developer Portal
Android SDK
Raspberry Pi EMS Guide
