I've given it permission and it still won't run.
Snoopy_hu
11-Garnet
I've created an account, I've granted it permissions, but it still won't run.Why? Please help.
Hi @Snoopy_hu ,
Pls follow the article for the non-admin users: https://www.ptc.com/en/support/article/CS227181
Kindly revert back if issue is still present.
Bhawna
6 REPLIES 6
Hi @Snoopy_hu ,
Are you trying to create a new user account and it is failing?
Regards
Bhawna
Hello @bchaudhary
I'm trying to run the mashup program with a non-administrator account, but the run screen is blank!
Hi @Snoopy_hu ,
Bhawna
Thank you very much.
Rocko
(To:Snoopy_hu)
You didn't explain what you want to do, so I assume it is editing a mashup?
You would have to give design time privileges.
Probably also access to some other objects/collections, might be easiest to put your user into Developers group.
Snoopy_hu
11-Garnet
(To:Rocko)
HI @Rocko
Yes, I'm trying to run a mashup, but the run is failing
