ICON Alignment in Button in Thingworx 9.X
pshashipreetham
18-Opal
is Icon alignment in button is possible? in previous version of Thingworx 8.x, ICON on button can be aligned, but there is no option to align in 9.x.
is there any possibility with CSS or any other workaround?
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
I made a workaround.
  1. Like Buttons and Value Displays have the clicked events. I have placed the Value Display(Transparent with no borders or background ...) and Image on the Top. Click on the Image or Label, and click Event Works.
  2. One most straightforward way is to Have a transparent button on top and z-index the Image on the background.
Shashi Preetham,
5 REPLIES 5
Hi @pshashipreetham
I believe in ThingWorx 9.x, the icon will align with the label inside the button, which is controlled by LabelAlignment property. You might try it, unless you want to separate the label and the icon.
Hi @CharlesJi ,
Thanks for quick response, I want Label to be in the Bottom and the ICON on Top, which was possible previous 8.x version, But I can't see it now.
Shashi Preetham,
Hi @Shashi_Preetham.
You can submit a request for this on the ThingWorx Ideas forum.  Be sure to indicate the version of ThingWorx you're running and details regarding the request.  Which button widget are you using?  Screenshots would be helpful.
--Sharon
Shashi Preetham,
Try add custom css class with direction: rtl
.rtl {
    direction: rtl;
