Image upload functionality from local storage in a mashup.
AV_10867476
I have a mashup container where i want to have the functionality which allows the user to simply select the file and then the file gets displayed in the image widget. I tried different thing but pretty confused about the bindings which will be there for this specific functionality. This is the skeleton of what i am trying to achieve:#111.png
I checked the ticket where the user has provided a widget extension, but while importing it fails to validate and throws some error "Extension Exception: java.util.zip.ZipException: zip END header not found" .
Is there a way, without using a custom extension to achieve the desired file upload Functionality, something like this:
Hi @AV_10867476
     You can create a custom widget according to your requirements.
