Import from local to cloud throwing error @ version 8.5.3
SAnusha
Hello everyone
I am trying to replicate the same project from local to cloud.
Exported the source control entities to "System Repositories" and copied the same zip file to cloud i.e. "Virtual machine" system repository.
Throwing "Import Failed" error.
SAnusha
(To:PaiChung)
Hi PaiChung
Thank you for your response.It has worked after media entities imported to cloud separately.
3 REPLIES 3
PaiChung
22-Sapphire I
(To:SAnusha)
Try unzipping the file into a set of folders in the repository and try import again?
I am not sure if you are pointing directly at the zip, but I thought it couldn't import from a zip.
SAnusha
(To:PaiChung)
Hi PaiChung
slangley
23-Emerald II
(To:SAnusha)
Hi @SAnusha.
If the previous response helped you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same issue.  If your issue is unresolved, please provide further details around what you have tried and the results.
--Sharon
