In Time series chart X axis date-time is over lapping
msahu-3
in ThingWorx 7.3 in Time series chart date time is over lapping with each other. Even after giving  \n which should make Date and Time in two different lines does not work any more (Overlaps) after migrating to 7.3 from 5.4. May this is happening because less space available. Is there any one facing the similar issue ?
posipova
20-Turquoise
(To:msahu-3)
Could you please supply a screenshot and, if possible, your entity from 5.4 so we could reproduce the issue? If a defect is confirmed, I will submit a Jira on your behalf. Thank you!
Hi Polina, Thanks for quick response.
here are the attached screen shots
posipova
20-Turquoise
(To:msahu-3)
Thank you for providing the screenshot. I sent you a private message.
