InactivationCheck in GetRunTimePermissionsAsJSON or GetRunTimePermissions
pshashipreetham
18-Opal
I am trying to get the Permission of a Thing in JS Code, when you services like GetRunTimePermissionsAsJSON  or GetRunTimePermissions I get the InactivationCheck in the output of the Service.
If I Run the Service from the Thing, by opening and executing it, I can see the data properly.
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
I made a workaround as of now.
  1. Created a service in each thing, which sets GetRunTimePermissionsAsJSON or GetRunTimePermissions data to a dummy property.
  2. Later, I created a Helper Thing, where I made a service that calls/Fetchs all the property data from the Things we set in Step1.
This modified workaround gives me all the Things permissions data.
Shashi Preetham,
5 REPLIES 5
And you made sure there is no group (accidentally) called "InactivationCheck"?
Please also always include which TWX version you are running. (It did work for me on a 9.3.10)
Hi @Rocko ,
Thanks for quick response, and apologies I missed Thingworx version, as of now Thingworx Version is 9.2.6.
and yes, there is no user group with "InactivationCheck".
Shashi Preetham,
I don't have a 9.2 around to test, but I've never seen this before. You could try running this with a different user. If it persists, create a ticket with support.
Shashi Preetham,
Thank you for sharing your solution with me. You've made a difficult task seem easy
