Infotable View String Error
eazzarito
Hi everyone,
The issue is about infotable enhancement. When a value is set, it is displayed as a string and not as an infotable. All this in the data shape. If I create a property under the thing this doesn't happen. If I restart thingworx though, I see infotable valorized correctly but when I send a new value it returns string.
Immagine 2021-07-06 233205 as it is.
Immagine 2021-07-06 233300 as it should be.
Thanks for the support
2 REPLIES 2
PaiChung
22-Sapphire I
(To:eazzarito)
It looks like you are not adjusting your information in your service to create an infotable payload to update the table, it seems to be receiving a json instead?
slangley
23-Emerald II
(To:eazzarito)
HI @eazzarito
If the previous response allowed you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same issue.  If you found a different solution, please feel free to provide it.
--Sharon
