Hi everyone,
The issue is about infotable enhancement. When a value is set, it is displayed as a string and not as an infotable. All this in the data shape. If I create a property under the thing this doesn't happen. If I restart thingworx though, I see infotable valorized correctly but when I send a new value it returns string.
Immagine 2021-07-06 233205 as it is.
Immagine 2021-07-06 233300 as it should be.
Thanks for the support
It looks like you are not adjusting your information in your service to create an infotable payload to update the table, it seems to be receiving a json instead?
HI @eazzarito
If the previous response allowed you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same issue. If you found a different solution, please feel free to provide it.
--Sharon
