Invoking a Thingworx Service multiple times
SaranKarthick
Hi developers,
I have a requirement where the user can select multiple things from a list and a particular service should be invoked for all the things. The issue I have is, for each and every thing i need to execute the service individually. I need to execute it continuously for all the things. Please advice.
Thanks and Regards,
Saran
You will either have to use a Collection or in older versions a Repeater widget to show multiple Nav buttons
Or show the links in a Grid or List
In your setup, I might almost just add the link onto the payload of the Things that the user can select from and show that in a Grid so they can click the link within the grid to navigate.
Sorry if that totally doesn't match your use case.
My initial answer was more for Server side execution of the links, but if you have to return URLs then perhaps some of what I mentioned can help.
6 REPLIES 6
You can pass in the selected Things as an info table
then loop through the infotable
and invoke your service with that Thing as an input parameter
Now if you need to very dynamically invoke you can use
Things(ThingName)(ThingServiceName({Parameters}))
(or something similar)
Hi @PaiChung,
Thanks for your reply. The issue here is the Service will take the thing name and provide a url link. This url link is passed to a link widget. So if i pass the list of things as an infotable, the the result url will be for the last item of the infotable. Even if i make the result to be an infotable of respective urls the link widget can only take one at a time and it can be executed only once. So i need to execute the service multiple times in the run time of the mashup.
Hope i had provided a clear picture of my issue.
Thanks and Regards,
Saran
Hi @PaiChung,
The repeater widget solved the problem. Thanks for your help.
Saran
Is there any means to get the response url written in a file?
PaiChung
22-Sapphire I
(To:KavithaR)
Can you describe a little more what you are doing?
Is this still something you need to do client side vs. server side?
