I am using guide for connecting Raspberry Pi 4 to thingworx. But thingworx is not updating value from raspberry pi 4. It is remaining on zero even after showing in raspberry pi 4 terminal that all 3 properties are updated. Please help me to solve this probelm. Is it problem with raspberry pi 4 or what??
Preet
Hi @Preet98.
For troubleshooting this issue:
If these steps do not help to pinpoint the cause of the issue, please upload the config.json and config.lua file and the log of messages when starting these two processes.
--Sharon
Hi @Preet98.
--Sharon
Hi @Preet98.
If the previous response led to a solution to your problem, please mark it as the Accepted Solution for the benefit of others with the same issue.
Thank you for your participation in our community!
--Sharon
