Is it possible to change languages of UI in ThingWorx at runtime without using Runtime preview.
Chiranjit_994
I have a use-case where in users want an option to change languages at runtime but not using the Runtime overview OOTB option of ThingWorx. Has anyone implemented or worked on similar use-cases.
Hi @Chiranjit_994
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Best regards,
Catalina
PTC Community Moderator
PTC
javed_a
(To:Chiranjit_994)
You can give a dropdown on page and on change you can set preference of language, refer below discussion:
Switch language preference on demand - PTC Community
Thanks!
Javed Akhtar
In the user's detailed page, go to "General Information" tab, user can change the "Language" for the user's preference locale .
