Is it possible to do integration between ThingWorx and Microsoft Dynamics?
Tanzanite
Microsoft Dynamics is a line of enterprise resource planning (ERP) and customer relationship management (CRM) software applications.
If not possible directly then is integration through third party app/plugin possible?
Tags (1)
4 REPLIES 4
Highlighted
Re: Is it possible to do integration between ThingWorx and Microsoft Dynamics?
I am not an expert in Thingworx, but I know that it can very easily call any RESTful API. It seems like Microsoft have added a RESTful API to their 2016 version of Dynamics CRM.
The MS Dynamics ERP does not have a RESTful API, so you might be able to use the SQL database connector from the marketplace. This connector will allow you to query data from the database, I am not sure if you will want or even be able to write to the database. Bear in mind that "integration through a database" is difficult to get right and generally a bad idea for integrating off-the-shelf products.
Highlighted
Did you get this working?
Highlighted
Wow.  I can't believe it's been a year since I posed this question.
Yes.  We have it working now. We created a thing template to connect to Microsoft O Data and then a thing with a service that passes in parameters to Dynamics CRM API.
Highlighted
Would you be willing to add some detail around the thing template you created to connect to Microsoft O Data?  I think I have the Azure side figured out as far as keys and application permissions.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
