I use a 24" fullhd screen, but seems limited in particular when working with mashups.
with previous composer (8.3) it was quite enough, but now with the new composer (TW 8.5) more size seems required. I need sometimes to zoom-out with the browser
Is it better a 4k screen on a 27 inch ?
What do you use ?
Regards
Hello @iguerra,
It seems the minimum required resolution of 1280x800 is for Composer in ThingWorx 8.5. On a monitor of 24",in runtime, I tried with FullScreen, 1280x1024 and FHD 1920x1080 but there is a scrollbar that appears on the right. After doing a check on the web, it seems that 4k is usable starting with 27" or 28" monitor but it might be too big for most desktop scenarios.
