Hi all,
The goal is to be able to shutdown and restart the application or the server through a internal service. Is it possible ?
Thanks.
There is no such feature .
ThingWorx Foundation can be stopped /started/ restarted only via commands.
Hope this Helps!
Hope this Helps!
Hi @cbaurand.
Can you clarify your question? Are you referring to a ThingWorx service, or a service running at the O/S level?
--Sharon
i referred to Thingworx service.
