Is there a way to restart (shutdown-start) the server from a service?
cbaurand
11-Garnet
Hi all,
The goal is to be able to shutdown and restart the application or the server through a internal service. Is it possible ?
Thanks.
1 ACCEPTED SOLUTION
Ashritha
(To:cbaurand)
There is no such feature .
ThingWorx Foundation can be stopped /started/ restarted only via commands.
Hope this Helps!
3 REPLIES 3
Ashritha
(To:cbaurand)
Hope this Helps!
slangley
23-Emerald II
(To:cbaurand)
Hi @cbaurand.
Can you clarify your question?  Are you referring to a ThingWorx service, or a service running at the O/S level?
--Sharon
i referred to Thingworx service.
