jenscAnswer
You might be able to do it using custom CSS, but it is probably not recommended.
It is likely that creating your own Form widget would be the best option going forward.
There seems to be some libraries for it already, although perhaps not for free.
Jens
I don't recall seeing a widget like this.
What is your use case here? Do you want the user to fill out this form in a mashup?
Or do you want this form to be printed with some data from Thingworx in the form?
Or do you just want to let users print this form?
Jens
6-Contributor
I want the user  to fill out this form in a mashup.
jensc17-PeridotAnswer
Jens
