Is there any way to align panel right align??
sjung1
Hi, I'm doing some mashup designs.
I have some trouble in doing some layout.
Is there any way to align a panel in the column(in a horizontal layout) in right aligned??
3 REPLIES 3
supandey
(To:sjung1)
Hi Soon, could you please clarify if you wish to right align the panel itself or the contents of the panel?
Ascherer17
(To:supandey)
I'm wondering about this as well.  If I'm thinking about this correctly, in a "Responsive" mashup, the only thing a panel can be moved around inside is another panel.  So the panel itself would be the contents of a panel.  Otherwise the panel would expand to fill a responsive container.
Do you have an explanation of how to right align/anchor contents of a panel to the right side of the panel then?
khayes1
(To:Ascherer17)
If you put a panel inside another panel you will see some properties to anchor the inner panel
       Unfortunately you can only align 'left' or 'centre'. I don't think there is a 'right align' option.
