Is there any way to set several redirect URLs after timeout?
chiwatashi
Customer has several organizations and each organization have "Form login" pages.
Customer wants to redirect to form login pages (<servername>/Thingworx/FormLogin/<Organization Name>) after timeout occur.
Is there any way to set several redirect URLs after timeout occur with condition user/organization?
3 REPLIES 3
Aanjan
(To:chiwatashi)
Chikashi, you can redirect users to a specific URL using this REST call:
http://<server>/Thingworx/Server/*/Services/Logout?method=post&_redirectURL=<URL>
You would need to write a custom service around it though.
chiwatashi
(To:Aanjan)
Hi Aanjan
Thanks!
If we use services, I guess we need to know the current session idle time.
I saw the "CurrentSessionInfo" and "UserManagementSubsystem", but could not find way to know the current session idle time.
The default idle timeout is "30", and I think the tomcat monitor it with JSESSION ID cookie.
Is there anyway to know the current session idle time?
paic
(To:chiwatashi)
Can not really be done based on Time Out, however if they are using SSO, with the Authenticator at least when a re-auth comes up, it should be able to pick that up and re-direct to the proper page.
