Is there life cycle management for the persistent data in Thingworx ?
seanccc
I got the requirement from a customer:
"The data stored for query remain 3 months,  then the data is regarded as "cold data" , user can still query it , but the data should be moved(not removed) to somewhere, like archive database or data warehouse. So that the "cold data" doesn't affect the query performance. "
This is something like life circle management of data and it's necessary for the time-series data I think , like value stream or stream.
Does thingworx supports it natively ?  I mean the the archive database and archive strategy can be specified during deployment and developers don't need to care about querying data query from archive database or live database.
Sean
3 REPLIES 3
PaiChung
22-Sapphire I
(To:seanccc)
there is no OOTB archive functionality.
So you would need to create this capability.
probably create a separate data store (external DB separate persistence provider)
and create a separate set of services etc. to handle 'live' short term data vs. the historical data.
seanccc
(To:PaiChung)
Hi PaiChung, Thank you for the hint. Is there any guide or sample for creating a new external DB separate persistence provider ? Regards, Sean
