Issue in Permissions for File Transfer subsystem copy service
harpreetk
I am facing permissions issue while using File Transfer Subsystem Copy service execute as below :
Error message is as follows:
Error: CopyInternalError:Not authorized for ServiceInvoke on CancelFileTransfer in RepositoryName - See Script Error Log for more details.
Internally Copy is failing because the remote thing is not connected that is fine but it internally calls CancelFileTransfer  service which I cannot find in FIleRepository. How I can assign run time permission for this service.
Harpreet
1 ACCEPTED SOLUTION
Try to follow the solution from here: https://www.ptc.com/en/support/article/CS283477
(I know it is not related to the Copy service, but could be a solution).
Hope it helps,
Raluca Edu
2 REPLIES 2
Hope it helps,
Raluca Edu
harpreetk
(To:raluca_edu)
Hi Raluca,
The link you provided was helpful. I have provided permission to this service for "Things" collection and it worked fine.
Many Thanks,
Harpreet
