I am facing permissions issue while using File Transfer Subsystem Copy service execute as below :
Error message is as follows:
Try to follow the solution from here: https://www.ptc.com/en/support/article/CS283477
(I know it is not related to the Copy service, but could be a solution).
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
Hi Raluca,
The link you provided was helpful. I have provided permission to this service for "Things" collection and it worked fine.
Many Thanks,
Harpreet
