JSON in Grid Widget
psp316r
JSON in Grid Widget
When Trying to display the threshold parameter in the Grid, it is showing [object][object], How values can be displayed.
Issue with JSON Variable Display on Grid:
@c_lowy @slangley @paic
Shashi
psp316r
(To:PaiChung)
Hi @PaiChung ,
Thanks for the quick reply, got it, should it be done from service or can it be changed in the GRID Configurations ?
followed a article here, but this didn't work.
Shashi Preetham.
PaiChung
(To:psp316r)
unfortunately the grid won't display json objects, you could convert it to string to display.
psp316r
(To:PaiChung)
Hi @PaiChung ,
Shashi Preetham.
slangley
23-Emerald I
(To:psp316r)
Hi @psp316r.
We tested under ThingWorx 9.2.3 and it worked fine.  Can you provide your code?
--Sharon
psp316r
(To:slangley)
Hi @slangley ,
It worked from the service, Thingworx version used here is 8.4...
Hoping this is the best practice and moving forward with this !!
Shashi Preetham
slangley
23-Emerald I
(To:psp316r)
Hi @psp316r.
Glad to hear you found a solution.
Please keep in mind that ThingWorx versions prior to 9.0 are no longer supported.  Due to the many bug fixes, feature enhancements, security updates, etc., it is recommended that you upgrade.
--Sharon
