When Trying to display the threshold parameter in the Grid, it is showing [object][object], How values can be displayed.
Issue with JSON Variable Display on Grid:
@c_lowy @slangley @paic
Shashi
unfortunately the grid won't display json objects, you could convert it to string to display.
Hi @pshashipreetham.
We tested under ThingWorx 9.2.3 and it worked fine. Can you provide your code?
--Sharon
Hi @slangley ,
It worked from the service, Thingworx version used here is 8.4...
Hoping this is the best practice and moving forward with this !!
Shashi Preetham
Glad to hear you found a solution.
Please keep in mind that ThingWorx versions prior to 9.0 are no longer supported. Due to the many bug fixes, feature enhancements, security updates, etc., it is recommended that you upgrade.
--Sharon
