The message you are trying to access is permanently deleted.
Hello Developers,
I m trying to install Thingworx analytics server -9.6.1 on my windows .but getting error below like:-
I installed java jdk 11.0.12 and also configured successfully. before installation of the thingworx analytics server I used ThingWorxFoundationMSSQL-9.3.9-x64 in my system and it works very well, however after the uninstallation of ThingWorxFoundationMSSQL-9.3.9-x64 and trying to install Thingworx Analytics server --getting above error.
please provide a solution on this.
Here, the path of Environment Variable JAVA_HOME is not correct, it should not include the bin subfolder, so it should be set like "C:\Program Files\Java\jdk-11.0.12" instead of "C:\Program Files\Java\jdk-11.0.12\bin"
Please check if your environment variable paths (JAVA_HOME and Path, in system environment variable) are correct, refer link below:
JDK 8u141 64-bit (Java SE Development Kit) (ptc.com)
Hii @javed_a
I checked in my system, steps are also same which is mentioned in the article sent by you. However still facing the same issue.
Open a cmd window, execute the below command and see if it returns Java 11.0.12 :
If the result of the above command returns correct Java version (i.e: java 11), then execute the below two commands and attach the outputs here:
Hello @Jimwang
Thank you for your response .
I run the above command which is mentioned .Please check the output.
Hello @Pratik_Aswale,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
