JavaScript code for ThingWorx widgets
SOLVED
Amethyst
May I know where I can find the JavaScript code (ide.js and runtime.js) for ThingWorx widgets?
The following path is what I am trying on my computer but to no avail as there are only images inside the widget folders. C:\Program Files (x86)\ThingWorxH2Trial-8.4.0-SNAPSHOT\tomcat\apache-tomcat-8.5.23\webapps\Thingworx\Common\thingworx\widgets
Re: JavaScript code for ThingWorx widgets
You may try installing older app version (8.1, for example), the code should be in that path.
6 REPLIES 6
We are moving towards web-components, there will be Widgets SDK released in the near future.
Thanks for the reply, but is there any way to retrieve the code of existing widgets?
I see, but I can't seem to find a download for older versions of ThingWorx online. I referred to this link https://community.ptc.com/t5/IoT-Tech-Tips/ThingWorx-8-3-What-s-new/td-p/553716 and tried to download ThingWorx version 8.3 but it says that my customer number is invalid as I am only a basic PTC user. Is there any other way I can download an older version of ThingWorx?
Unfortunately your download access is limited to your license/contract. You may try reaching out to your sales representative to see if there's anything they could do.
Alright, thanks for all the help!
