Kepware bad quality data not being sent to ThingWorx
ThingWorx cannot read the bad quality data from Kepware?
Hema
Hema
Hi
Just adding some extra info from
In KepServerEx, the Tag address becomes a bad quality in the following scenarios:
When there is bad quality, no data will be received by KepServerEx. Therefore, it will not be sending any data to Thingworx. The quality of the signals in the Thingworx will also be in the Bad Quality. If you have bonded to the Remote thing, you can write a logic to check which Signal is down.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
