Label chart
krishnakomal123
Label chart
Issue1 : I want to show x-axis,y-axis only.But when I give chartareastyle line color as black,It is showing borders on all sides
Issue2 : Y-axis,Secondaryyaxis labels overlapping with axis values
Please find the attached file.
The chart should be customized with CSS or with custom styles.
If you can attach export of the chart, together with data, I can try something.
Raluca Edu
Raluca Edu
Hi @krishnakomal123.
If the previous response helped you to find a solution please mark it as the Accepted Solution for the benefit of others with the same question.  If you still need assistance, please provide the information Raluca requested in the previous post.
--Sharon
