Labview and Thingworx Connectivity
pshashipreetham
18-Opal
Hi Team,
I was researching how to obtain data from LabVIEW to ThingWorx or the connectivity between ThingWorx and LabVIEW.
I found the article below, and I see that none of the links provided in the article (in the resolution section) are working. Can someone help us with working links?
Article - CS364839 - Integrating NI Labview and TestStandEnvironments with Thingworx 9.1
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
Check this posting with some links:
https://community.ptc.com/t5/ThingWorx-Developers/How-to-integrate-the-Lab-view-data-to-Thingworx-9-3-0/td-p/889079
and also this recording:
https://ni.adobeconnect.com/psqj0fprlrzw/
It indicates most users tried to do the communication via the HTTP vi from NI to Thingworx, not the other way around.
There might be other options using MQTT, AMQP or OPC DA to investigate on Labview side.
2 REPLIES 2
PEHOWE
(To:Rocko)
