Hi Team,
I was researching how to obtain data from LabVIEW to ThingWorx or the connectivity between ThingWorx and LabVIEW.
I found the article below, and I see that none of the links provided in the article (in the resolution section) are working. Can someone help us with working links?
Article - CS364839 - Integrating NI Labview and TestStandEnvironments with Thingworx 9.1
Check this posting with some links:
and also this recording:
https://ni.adobeconnect.com/psqj0fprlrzw/
It indicates most users tried to do the communication via the HTTP vi from NI to Thingworx, not the other way around.
There might be other options using MQTT, AMQP or OPC DA to investigate on Labview side.
@pshashipreetham , Did some searches and found the following links which are still valid:
