Last column values not showing in grid advances in ThingWorx 8.5
sagarmemane92
Hi ,
I am using the Grid advanced .After binding the data in grid,last column values are not displaying.
Sagar
Is the column in you output datashape?
If you added the column later, try a refresh on the mashup design data source and then rebind the data to the grid
Check grid column format and rendering as well to see if it is set to be displayed
2 REPLIES 2
Hi @sagarmemane92.
If the previous response provided a solution to your issue, please mark it as the Accepted Solution for the benefit of others in the community.  If you found a different solution, we would be happy for you to post it here and mark that as the Accepted Solution.
--Sharon
